RB211
Jan 27, 2015Explorer
'07 Southwind BR TV Removal?
One of my winter projects was to replace the older LCD flat panel TV's in the coach. The front went fine resulting in a new 32" display over the OEM Samsung 26".
The OEM 20" Samsung in the bedroom is fast becoming a problem. It's sitting on it's pedestal however it appears they used double sided tape to secure it to the shelf. I've tried to put a heat gun gently to the pedestal base and then slide a long icing spreader (I asked the wife first...) to get under the pedestal in hope of releasing the adhesive.
Doesn't want to give.....and before I do something I'll likely regret I thought I'd canvass the brain trust here for some input.
I've called the factory and they sent schematics but no mention of how it is secured down. I called the dealer and he said it was likely that it's been installed with the tape.
Thoughts?
Thanks in advance...Ron
Thoughts?
