Hi All, Name is Bill and the new owner of a Jayco Seneca 35gs. I pick it up in about 10 days so I thought it would be good to see what everyone has to say about that unit. Thanks Bill
I leave the exhaust brake switch on most of the time, Unless I am driving on hilly roads. Then I may turn it off to take advantage of the added speed that can be gained going downhill. I use cruise control most of the time. When going downhill I will sometimes put a little pressure on throttle pedal to keep exhaust brake from activating. As you drive your motorhome you will find what works best for you.
