timmac wrote:
tatest wrote:
timmac wrote:
What would be the best performance chip to go along with the Banks system, or would a computer flash as some have stated on other threads..
I thought that was part of the Banks system, reprogramming to make effective use of the other parts installed?
I am not sure what was involved since I did not have the system installed, I do know there was a programmer that came with the Banks system but it was not in the motorhome, 1st owner either kept it or someone got to it.
Does anyone know what the programmer did and is it worth buying a new one from Banks.
The Banks system is programmed for your rig. The programmer has the stock codes stored, so that if you need to take it to a Ford dealer you can use it to restore the original codes. I have also heard that the Banks setting may not pass muster with some emission testing - again programmer puts the stock program back. It can then be used to revert back to Banks.
