supercub wrote:
Have never done this before. I'm hooking up were there's only 110 service available. What do I do?? Will that keep the batteries charged, assuming I only run the TV etc. No Air Conditioners, I know. Would I plug into the 110 and then turn the invertor on and run off that or ?? Thanks
EVERYWHERE you hook up, is only 110VAC service. Do you mean that there is only a small 15A plug for the hookup? Plugging in to shore power (even a 15A plug) will provide 110VAC at your outlets and will provide 12vdc through the converter for lights, water pump, etc and battery charging. If you want to run AC, you'll likely need a 110VAC 30A supply.
