4x4van wrote:
supercub wrote:
Have never done this before. I'm hooking up were there's only 110 service available. What do I do?? Will that keep the batteries charged, assuming I only run the TV etc. No Air Conditioners, I know. Would I plug into the 110 and then turn the invertor on and run off that or ?? Thanks
EVERYWHERE you hook up, is only 110VAC service. Do you mean that there is only a small 15A plug for the hookup? Plugging in to shore power (even a 15A plug) will provide 110VAC at your outlets and will provide 12vdc through the converter for lights, water pump, etc and battery charging. If you want to run AC, you'll likely need a 110VAC 30A supply.
So you are saying those 30 amp and 50 amp plugs are 110 volt NOT 220 volt ??? So they are 50 amp 110volt ?? I was pretty sure when I ran an outside outlet at my neighbors house for his MH it was a 220 30 amp outlet....I am sure it was a double pole 220 amp breaker
