Two questions for the experts on this forum. I have a 2004 Jayco Granite Ridge 2900 with an inverter, should the 110 circuits work while I am driving? Also, what does the battery disconnect switch d...
Depends on the size of the inverter, but it should power most small things. If you need more: like AC and microwave - just run the generator. The disconnect switch is usually used when you place in storage to prevent battery drain. I have it for my coach battery in my older Allegro. Keep my current C plugged in 24/7.
