Two questions for the experts on this forum. I have a 2004 Jayco Granite Ridge 2900 with an inverter, should the 110 circuits work while I am driving? Also, what does the battery disconnect switch d...
We have a 03 Granite Ridge and the inverter powers only the plug for the TV. It is also set up NOT to work while the coach is in motion. Other Jayco owners have talked about disconnecting I believe the blue wire and the outlet with work when traveling.
