othertonka
Apr 04, 2015Explorer
I second the idea of getting and using a good volt meter instead of that light display. Also that switch you are talking about is probably bad, which can be most of your problems. Replace the switch. The switch usually needs to be ON for the convertor to charge your battery. A fully charged battery should read 12.6 volts with your new meter.
38,766 PostsLatest Activity: Jan 10, 2026
