jmttech wrote:
Thanks for the suggestions, I will check them in the morning. I am assuming that the "black cubes" I referred to are in fact relays. I'm assuming this provides isolation from the chassis cabling harness. So far I have not seen any specific documentation defining what the various relays control.
Good point about probing both ends of the fuses though. No short cuts recommended LOL.
Those "cubes" are indeed relays. They are mostly for Chassis functions like fuel pump, horn, PCM, etc... They have nothing to do with your problem, and neither do any of the fuses in that panel. Your problem in IN the BCC.
