jmttech's avatar
jmttech
12 V electrical problem
Hello all!
I have a 2009 Freedom Vision 3150 DS Class A motorhome. I believe it is the same as a Coachmen Mirada. The chassis is Ford F-53 and the manufacturer was, according to the VIN, Coachmen... However, it is/was "rebranded" by Camping World.
To the problem:
I was getting ready to make a small trip and when I started her up, the following failed to work:
Remote control mirrors,
Camera system was dead,
Cigarette lighter sockets (accessory outlets) were dead,
auxiliary dash fans were dead.
Map lights, radio, lights all worked. So far as I can tell, all "house battery" devices are working.
There are two fuse boxes to the left of the brake pedal on the drivers side of the firewall. The topmost (and largest one) appears to have power at all fuses and fuses check OK there.
The lower fuse box (consisting of 4 banks of 4 fuses) only has power to the lowest bank. The other three banks appear to be dead.
The main distribution box accessed from under the front engine cowling seems to have all fuses operational. I say seems because I did not physically remove the fuses to check, but used a continuity probe across the fuses. This may have been a mistake, but man there are a whole butt-load of fuses in this thing!
I did not check all the relays cubes as I am not sure if that needs to be don, I'm looking for input from this venerable group of more experienced RVers.
Any thoughts or ideas would be greatly appreciated. I really don't want to take it to the shop if I can avoid it. We are retired and income is finite.
Thanks in advance to all who may have input or experienced a similar problem.
  • Locate battery control center and find the ignition relay. It powers the rig's manufacturer's installed accessories.
  • Probe all the fuses with a test light. Ground the wire and probe the other end of the fuses. Check all the "box" fuses (I guess you're talking about resetable fuses). Those are how much of my dash electronics are powered. I'll bet you'll find something not getting power to the other side of a fuse somewhere.
