HealeymanExplorerSep 06, 201912 VDC Power at Rear ConnectorHi, Do any of you know if the 12VDC CENTER pin on the rear towed/trailer plug-in connector is Switched with the ignition or is it always Hot? RV is a Coachemen Leprechaun. Ford chassis Tha...Show More
Related ContentNewbie power questionRight rear leveler not retracting fully12 Volt Power Issue5th Wheel took out rear windowRear LP connector-hose?
