HealeymanExplorerSep 06, 201912 VDC Power at Rear ConnectorHi, Do any of you know if the 12VDC CENTER pin on the rear towed/trailer plug-in connector is Switched with the ignition or is it always Hot? RV is a Coachemen Leprechaun. Ford chassis Tha...Show More
LwiddisNomad IIISep 06, 2019They are not all the same, Healeyman. Most are like carringb posted but not all.
Related ContentNewbie power question12 Volt Power IssueRight rear leveler not retracting fully5th Wheel took out rear windowRear LP connector-hose?
