timmac's avatar
timmac
12 volt Cigarette/Round sockets at Dash Loss Power
I removed a old 3 way that was plugged into one of the sockets and a piece broke off inside and while fishing it out I popped the fuse to the 12 volt round sockets at dash.
So I checked all fuses on both the RV side and Ford side and no fuse was brunt out, do note these two round 12 volt sockets have power all the time without the key even being one.
So where did Fleetwood install the fuse to the 12 volt round sockets at the dash, I hope its not buried in the dash.
2008 Bounder on a F-53 chassis.
  • enblethen wrote:
    Mine is located under the hood driver's side. Mine has the battery disconnects, charge and ignition relay.
    Well I just checked the battery control box and no fuses burnt there, I will try and find that box and check fuses there.
  • Mine is located under the hood driver's side. Mine has the battery disconnects, charge and ignition relay.
  • enblethen wrote:
    My power receptacle is fused in the battery control center.
    Where is that located
    Update never mind I know where that is, I will try there, forgot all about that box..
  • Executive wrote:
    Unfortunately, it's buried in the dash. Trace the wire backwards and hopefully it's not too far back...Dennis
    That is what I am thinking is a inline fuse, I have tried finding it under dash but its very hard to get under my dash with out a drivers door, dang now I have created a big job from one stupid mistake..
    :M
  • Unfortunately, it's buried in the dash. Trace the wire backwards and hopefully it's not too far back...Dennis
