Off-Road_Racer_'s avatar
Apr 11, 2014
12 Volt Electrical issue?
To All:
I am a new Motorhome owner. This is an older unit. Originally all components worked properly. Now I do not have power to the control panel to view how full the water and waste tanks are. I am not able to run the water pump and the furnace will not run. I do have interior lights,Refrigerator and A/C when plugged in to the generator or garage. Where should I start to look for the problem at? I have check the fuses.
Thanks
Kevin
  • If your lights work on shore power but other 12V things don't, then you've got a 12V power distribution problem. It's either fuses or something wrong with the converter.
    Steve
  • There are some books at RV supply stores that explain basics of RV electrical and other systems and may include troubleshooting and maintenance information. Fleetwood might be able to provide generic electrical wiring diagrams but these are not specific to your MH. Old rigs like, yours have often been repaired/modified by amateur DIY types. If you have friends that understand automotive electrical systems, they may be able to help you, otherwise find a good RV repair service and pay their rates to get your RV working properly. some automotive electrical shops are experienced with RV systems too.
