Off-Road_Racer_'s avatar
Apr 11, 2014
12 Volt Electrical issue?
To All:
I am a new Motorhome owner. This is an older unit. Originally all components worked properly. Now I do not have power to the control panel to view how full the water and waste tanks are. I am not able to run the water pump and the furnace will not run. I do have interior lights,Refrigerator and A/C when plugged in to the generator or garage. Where should I start to look for the problem at? I have check the fuses.
Thanks
Kevin
  • Fuse! How did you check them? Unless you used a volt meter just looking is of no use.
  • I'd check voltage at your house batteries, battery disconnect switch, and battery cable connections.
