wa8yxm
Jul 10, 2019Explorer III
I will go with the inverter option If you have an inverter it may be off. Fuse blown (DC) or circuit breaker (AC) tripped.
As others have said usually the ignition interlock (It's a relay in the outlet box the TV is plugged into) only applies to the FRONT TV where the driver can contort to see it.
Now I'm fond of saying many RVers have a few screws loose.... I had some A/C issues when my rig was new.. One of the screws in the power distribution center (Breaker box) took over 3 FULL TURNS before it was tight.> A/C worked much better after that.
