enblethen
Jul 18, 2019Nomad
Do you have one of the small receptacle testers? Little yellow plug in device. This will help telling whether it is getting power or whether one of the legs is open.
Use a volt meter and check to insure you have power out of the inverter(s)
Remove the gfci recptacles from the wall, test with voltmeter to verify that you have 120 volts AC on the load terminals. GFCI receptacles protect down stream devices with this function.
