opnspaces wrote:
How much power does the meter show? If the is no fuse, or the fuse is oversized you might have burned up the wire and only a few strands are left. This is enough to read 12 volts on a meter, but not carry any load. I would pull the outlet back out of the dash and check the connections for heat damage.
Actually thinking about it, I'll bet the fuse partially blew so they all still look good. Plug something in with an LED, and pull fuses until the LED goes out. Then replace that fuse.
Hi there. Yes, 12.5 V on each socket. But as you say, somehow not enough power. I was thinking about a partially blown fuse as well. Unfortunately, there is no fuse marked for 12 V outlets, strangely enough.
