Bobalooie's avatar
Bobalooie
12v Accessory socket issue
I have a 2000 Dutch Star. There are two 12v sockets on the dash. One came loose and in trying to put it back, there was a spark. I screwed it back in. The meter shows power still, but... it's not supplying enough power now. If I plug in an FM transmitter, there's just enough power to light the LED, but not enough to run the transmitter. It's really weird. Both sockets are doing this. I can't find a fuse that is blown.
What is going on?
  • How much power does the meter show? If the is no fuse, or the fuse is oversized you might have burned up the wire and only a few strands are left. This is enough to read 12 volts on a meter, but not carry any load. I would pull the outlet back out of the dash and check the connections for heat damage.
    Actually thinking about it, I'll bet the fuse partially blew so they all still look good. Plug something in with an LED, and pull fuses until the LED goes out. Then replace that fuse.
