Sam_Spade
Jun 29, 2017Explorer
mmoore43 wrote:
Does any of this make sense as to why my 12V batteries are not charging when I am plugged to shore power?
I see that there are other answers.
Simply, you can NOT charge a 12 Volt battery with LESS than 12 volts out of the charging source. 10 volts is not near enough.
Your converter/charger has failed.....or has a blown fuse or bad connection.
P.S. And you can not be sure that your batteries are "fine" unless and until you see if they will charge all the way up....and hold that charge when not being used.
