ACDNate's avatar
ACDNate
12v power issue
2008 Winnebago Journey 39z.
New issue presented itself today. Randomly half of the 12v powered items in the coach have no power. Everything working one moment. Was out of the coach for 20min and when I went back in half not working.
I've got 12v power to stereo's, awnings, some lights. I don't have 12v power to main lights, control panel that shows power status, tank levels. I do have power to thermostat (assuming it uses a 12v power supply for something), the water pump powers.
Checked all 12v breakers, house and chassis. None tripped
110v power good weather on shore power or generator.
Buddy who's had similar issues before said there's a solenoid that dispenses 12v power to the coach that can stick. He recommended turning on generator and then off to work the transfer switch and activate the solenoid. Did that a couple times and 12v power came back.
40 min later I lost half 12v power again.
Tried turning off house batteries with switch at door. This turned off the remaining 12v items on. Turned back on after a short time and still have only half 12v power.
Are there more than 1 solenoids that control 12v power? I notice there are 2 button breakers for 12v power to the inside 12v panel.
Any suggestions what else to look at?
Thanks,
Nate
  • That was my first inclination. My gut says a solenoid isn't activating. That theory would indicate the system is split though since I do have some 12v working.
  • Flip the Salesmans switch by your steps a couple of times. On my coach I sometimes have to hold it for a few seconds for the relay to switch.
