bullydogs1 wrote:
Monaco is famous for the solenoid for 12v cutoff that fails...the solenoid is in the left front outside compartment under the driver...in there you will find a solenoid that can be bypassed until you get a chance to replace it...sorry I don't have a picture but you can't miss it....if you call Monaco support they will send you an email of what it looks like and you just have to jump the connections.
Sounds like Monaco uses the same 12v type solenoid switch that Travel Supreme uses. I just replaced our solenoid this morning original since 2003. We had the same problem all 12v was off in the MH. We have a switch at our entry door that turns the 12v on or off, and after testing the switch was good. So I ordered a spare Cole Hersee - 12V Insulated Continuous Duty SPST Solenoid at
http://www.partdeal.com/cole-hersee-12v-insulated-continuous-duty-spst-solenoid-boxed-pkg-24059-bx.html to carry in my MH.
It was easy to change and in the future if it goes bad I will have a spare.
