Bigdummy86
Oct 15, 2015Explorer
12v problems with 2005 allegro
Hello -
I'm new to the forums and because of my remote location I'm looking for some assistance.
Last time I took out my 2005 tiffin allegro class a out the generator had failed to charge my batteries, and I ended up using the chassis to do the charging. I have since replaced the inverter which I tested bad with a voltmeter. Now that I have the new inverter in, and even if I remove the inverter I have no 12v power for anything. I've done some basic testing near the inverter and everything seems to read okay. Both batteries are charged to 13+volts (chassis and house batteries). I've got a few hours into this already.
I have tested fuses and everything looks good. Any suggestions where to look next? Curious thing is that I have a solenoid that reads lesser 11.5 V when I test it across the main ground. I would think even 11.5 volts would be enough to power my 12v system.
I also hear a "clicking" noise when I press the 12v switch to try and turn it on, very similar to when a car battery fails to start a car. This is coming from a solenoid that reads the full 13v.
Any other suggestions to what to test or what may be wrong? I've tried jumping across the solenoid that reads 11.5v and still had no success.
