uccrev's avatar
uccrev
12V problems
I purchased a used Class A -- All works well, but am having problems with using 12V. Human error? or mechanical/electrical?? We did not have electric hookups, so was able to use the generator (worked great). When we shut the generator off... the LP gas for the refrigerator kicked on and ran well... until I turned on a light (on the 12V system). As soon as I turned the light on (or water pump) the refrigerator lights started blinking, the LP stopped and there was no power to the refrigerator. Also, when I tried turning 12V light/pump on, the alarm would beep on the CO2 monitor... Am I suppose to do something to run on 12V or should it automatically work?? Any suggestions on fixes, etc.? Thanks.
  • Bad ground. Clean and re-tighten all battery connections and find where the negative attaches to the chassis, unbolt that and wire brush the hell out of it.
    Also, some coaches switch the negative side on what's called the salesman switch. Check the connections on that and squirt some contact cleaner in the switch.
  • Sounds like low 12 VDC power or possibly bad batteries. Not enough amperage from them. Have the batteries tested, then check connections.
