We are looking at a 30ft class C that only has a 13.5 BTU AC unit installed with 30 amps power cord. We are concerned that this set up will not be sufficient to get through these sweltering summe...
So, does the Reflectix HAVE to put on the outside of the windows? Or, can you put it up from the interior and still get the same heat reduction? If it has to go on the outside, guessing I might just gorilla glue it to my Class C vinyl exterior privacy cover so it stays in place and can be easily put up/removed. Can some clarify if this would be ok? If I do this from the inside, it'll be difficult keeping them in place without using tape or Velcro.
