Ramair's avatar
Ramair
13.5 rear AC amps
I believe that my rear Dometic 13.5 ac is out of Freon. Everything was working great until a fan blade broke and cut into the condenser fins. Replaced the fan and all is working but not blowing cold air. When running fan only all is working but when switching to cool (ac) I hear the compressor kick in but not blowing cold air. Called dealer and was advised to check the amp draw of the compressor. I know when all is good its should pull 12.5 amps, what would it pull if it was out of Freon. Any help would be greatly appreciated.
  • Sounds like the cut condenser fins may have sprung a leak.
    And it is now time to replace the AC.
    You may think about a Heat Pump 15K unit.
  • Probably a lot less. Don't know for sure.
    Give it a try.
    Let us know what you find.
