- SRTExplorer
BelleStarr71 wrote:
Primary tank was full.We think it may have went bad as it sat. He says engine purrs when it is running. But, it has backfired. Maybe you are right. I will pass your suggestions to my husband. Thanks.
The bad smell is usually indicating old gas. If you can I'd get rid of about a half tank of the current gasoline and fill it up with new gas. Probably a good idea to change the fuel filter and put Seafoam additive in the tank when you fill it. You'll have to change the fuel filter again after a tank full has been run through.
Good luck. - BelleStarr71ExplorerPrimary tank was full.We think it may have went bad as it sat. He says engine purrs when it is running. But, it has backfired. Maybe you are right. I will pass your suggestions to my husband. Thanks.
- rgatijnet1Explorer IIIMaybe all of the above needs serviced. You may try some starting fluid to get it running and top off the tank with fresh gasoline and add an additive to absorb any moisture in the tank. It may also need the fuel filter to be changed.
38,763 PostsLatest Activity: Jul 22, 2018
