BelleStarr71's avatar
BelleStarr71
1978 Dodge 440: Gas has funny smell, Backfiring, etc
Just purchased this beast. We are brand new at this so any help is greatly appreciated. Already replaced battery, but driving it from Lancaster OH to Columbus OH it decided to not start after driving it for 3/4 of the distance. The gas smells off. Engine tries to catch, but just won't. Thinking maybe bad gas? Need plugs and wires?
  • BelleStarr71 wrote:
    Primary tank was full.We think it may have went bad as it sat. He says engine purrs when it is running. But, it has backfired. Maybe you are right. I will pass your suggestions to my husband. Thanks.
    The bad smell is usually indicating old gas. If you can I'd get rid of about a half tank of the current gasoline and fill it up with new gas. Probably a good idea to change the fuel filter and put Seafoam additive in the tank when you fill it. You'll have to change the fuel filter again after a tank full has been run through.
    Good luck.
  • Primary tank was full.We think it may have went bad as it sat. He says engine purrs when it is running. But, it has backfired. Maybe you are right. I will pass your suggestions to my husband. Thanks.
  • Maybe all of the above needs serviced. You may try some starting fluid to get it running and top off the tank with fresh gasoline and add an additive to absorb any moisture in the tank. It may also need the fuel filter to be changed.
