2Bargos
Jun 17, 2014Explorer
In my business (starter/alternator rebuild shop) I have experienced this on several occasons.Problem is the alternator belt is slipping and burning the belt off.By looking at pics of your alternator pulley I can tell its been very hot caused by belt slipping.
IIRC the 84 model uses either a 15 or 17 si delco alternator ,the units were a bear to pull and many had same problem you are having
Don't be afraid to tighten the belt.
try tighten the belt until you can turn engine by placing a wrench on nut on the alternator and rotating it.
After a run n time check belt tension again.
38,783 PostsLatest Activity: Sep 09, 2026
