turbojimmy
Jun 18, 2014Explorer
Okay - fixed the PS pump. It wasn't slipping, but that belt never would have held up. First, it was in the wrong crank groove. Second, the pump was loose in the bracket allowing it to pivot toward the water pump.
Before:
After:
I'm hoping a new belt and proper tension will fix the alternator belt. I don't know what would cause it to be misaligned. I dug out the other set of pulleys and they're identical. My recollection was incorrect - the crate engine WP pulley only had one groove that appears as if it lined up with the alternator. The stock engine WP pulley has 2 grooves - one for the alt and one for the ps pump. That's the one that's installed. Both crank pulleys are identical, with 3 grooves. The third groove appears to be for a second ps pump pulley which I understand they stopped using at some point. I've seen older (70s) 454s with both belts, but it's obvious a belt has never ridden in that spot on my ps pump nor on the crank pulley.
Before:
After:
38,783 PostsLatest Activity: Sep 09, 2026
