haydoracin
Jul 26, 2014Explorer
Had the same problem several years ago with a 1984 Pace Arrow. Thought the alternator was bad. Removed and had it tested and it was fine. Was also throwing belts. The alternator problem ended up being the bolt that you tighten after tightening the belt was bad and though it appeared tight it wasn't. If I remember correctly it had metal in the threads that wouldn't allow it to tighten all the way. New bolt and never had a problem after that. Also had to remove the smog pump as it was misalligned
38,783 PostsLatest Activity: Sep 09, 2026
