77rollalong
May 09, 2018Explorer
Check fuel pressure on the fuel rail test port, also could have problem with the mass air flow sensor between the throttle plate and the air box, and scan it to see if you have any codes stored could help as well, if you need the fuel pressure specs i can look them up.. one other thing to check is the fuel pressure regulator , could try and pinch off the return line to see if that helps too
38,782 PostsLatest Activity: Sep 10, 2026
