Without regard to the MH part of the chassis and how well that all works, I have a hard time believing that a 33 year old Chevy is in better mechanical condition than what you have unless yours is in need of work. You’re buying something unknown.
Carb vs efi? 87 should have been TBI afaik. First year of it. So it’s likely been swapped for a carb. Not necessarily bad, but depends what’s on it For a carb and the ignition would also be swapped for older vac advance.
I have a carbed Vortec Chevy with an older ignition and it runs great, but requires attention and knowledge.
Basically you’re buying an antique vehicle. IMO that and carefree RV ing don’t go together unless it’s very well sorted out and documented.
And it’s either a 3 speed auto which in itself is simple and reliable but of unknown history. I don’t think 87 1 tons got the 700r4 but while it’s an OD trans, it’s inherently worse than the old TH 350/400 trans.
I’d pass unless you’re open for a potential serious project. You said your handy, but don’t sound like a mechanic knowledgeable about these vehicles.
