Bordercollie
Jun 15, 2013Explorer
Plug the power cable plug into the generator receptacle, then start the generator and let it run for a couple of minutes, move the AC control to the fan position and then to the "cool" setting. Adjust the thermostat to colder than the ambient temperature and the compressor should start and cool air will eventually come out the vents. If you shut off the AC, don't try to turn it back on right away. It needs to "rest" 10 minutes before re-starting the compressor at the "cool" setting.
38,778 PostsLatest Activity: Jun 07, 2026
