theoldwizard1
Apr 17, 2018Explorer II
Motorcraft Synthetic Blend oil is plenty good and cheaper than any full synthetic. Just use the proper viscosity.
Type F ATF is long gone. Use Motorcraft Mercon V. Don't waste you money on a synthetic.
If that chassis is really 30 years old, I would replace ALL of the brake lines and hoses, the pads and shoes, calipers and wheel cylinders, springs and hardware. If you are going to DIY the brakes, use nickel-copper (NiCopp) brake lines. Easy to bend and flare.
38,777 PostsLatest Activity: May 24, 2026
