Andonso
May 30, 2018Explorer
Electric 1988 E-150 Okagagan Camper Van
After moving the van, had a chance to take a closer look at the interior.
The van has an AC/DC converter with two glass 15 amp DC fuses and a 120 Vac receptacle to plug something AC in, but no breaker that I can determine (without removing the AC/DC converter from it's installation under sink next to the frig.
The AC does power a Dometic RM-2301 Gas/Electric frig.
I tested the frig set to "Elect" and seems to run just fine keeping things frozen and cold when plugged in to 120 Vac. Settings show "gas", "elect" and "12 volts"
It does have an exterior AC cord that uses a standard three prong AC plug with hot, neutral and gnd.
I'm unable to see any AC breaker only two cylindrical glass DC fuses which appear to be 15 amps each. Alot of wires inside around the converter some of which go to the water pump and refrigerator.
There is a small furnace which fan turns on but hasn't produce any heat. Appears to be a gas only furnace as there's empty lpg tank with valves, located on the side underneath. Appears furnace must be also connected to the ac/dc converter along with the refrigerator.
I'm uncertain if the converter has a battery charger. There is a space for a house battery in the engine compartment with a relay and some wires, that I haven't yet figured out.
I'll try and identify the converter, perhaps take some pics and post them. The older converter appears one used in b vans from the 1980s, not your standard 30 amp converter found in Class C and A motorhomes from that era. From the exterior appears may be a Parallax converter without any AC breaker. The cover is dark brown with AC receptacle and two cylindrical dc fuse holders.
