Andonso
May 30, 2018Explorer
Pic of power center. There is a push/pull switch labled push ON pull OFF, below the AC plug so I suppose this is the AC breaker?
There are two dc 15 amp fuses. Two other dc fuse spots with plugs.
Pulled the power center and found some details.
System Monitors Inc. Model Number MSM 200 D.
120 VAC 20 amps AC
12 Volt (dc) output 20 amps total
with 5 amp battery charger
Has two DC 15 amp fuses and one internal 4 amp fuse (which was blown)
Anyway it appears when connected to AC it will charge the house battery with up to 5 amps.
I found a label with product numbers of equipment installed.
Hydroflame FA 7615 (gas)
Wedgewood W7103 (gas)
Dometic RM2301 (gas elec)
Jensen CP120 (elec)
Manchester 6102 (Gas)
120 VAC 20 amps AC
Jensen CP120 (elec)
