- BobRExplorerI just slide it back and lean over it to check fluid level. If you need to remove the doghouse, tilt it to vertical position as soon as it clears the dash lip. That will keep the bolt down tabs from interfering with the seats.
- If you have a tilt steering wheel, put it all the way up. If your seats swivel, turn them so the narrowest part (normally the back) is facing the cover, that should give you enough room to remove the cover.
- 1989chieftain2nExplorerI wish it was that easy everything else is under hood but that and of course plugs and stuff but not transmission stick I might mention it is a chevy engine
- doxiemom11Explorer IIFirst thing that came to my mind was ---- isn't there a dipstick under the hood to check the transmission fluid with? Our engine cover would not get stuck between the seats, but we are a wide body model.
