Grit_dog
May 02, 2022Trailblazer
opnspaces wrote:
It sounds like a plugged cat to me. With a willing helper start the truck and in neutral rev the engine a few times. Have the helper stand in the back stick their open palm by the exhaust and feel the strength of the exhaust coming out while you rev it. Then go for a drive and when it slows down pull into a parking lot and have them feel the exhaust again.
When it loses power will it still rev in neutral?
Does power level temporarily go back to normal after it gets towed home?
Pull the cat and see if it's plugged or rattles. If it;s welded on then maybe talk to a local muffler shop guy have them cut the cat out and see if it's plugged. If not plugged they can weld it right back in.
I'm believing this is the most likely issue and where I'd start as well.
If you can even reasonably verify you think there is a restriction, (if there's not, it'll only cost you a $20 band clamp to repair the self inflicted damage I'm about to suggest) I'd cut the exhaust pipe off just ahead of the cat, in a spot you can clamp it back together, move the cat aside a bit, tie it up or whatever and take a run with it.
Hope you go the garbage disposal fixed! Its always something aint it??
38,782 PostsLatest Activity: Sep 10, 2026
