TheWanderer's avatar
TheWanderer
Ford 460 motorhome running hot
Hello again everyone!
Just wanted to check in after all the recent repairs with a new and exciting issue! Haha well kind of new.
So the 460 engine in my 1988 ford E350 motorhome is running pretty well, idling fine, starts fine, runs down the road with no spitting or sputtering...except that it is running temps up to about 220 when run for very long at all, and still seems sluggish on accelleration or under load particularly when hot.
I ran it about 200 miles the other day and it got hot enough to melt the split loom off my plug wires. I heat wrapped a few things like the egr pipe and exhaust near the starter to reduce wear on components and heat in the cabin but need to figure it out within a couple weeks if possible before any longer runs again.
I am about 6 miles from the nearest town and they do have an advanced auto there. Can probably safely run it about 15-20 miles round trip at a time before needing to let it cool down to avoid extra wear on stuff. Further if absolutely necessary. Hoping for no big money repairs as I already went pretty broke with previous repairs.
Thinking perhaps a fuel pump or injector issue?
I will list the replaced parts and work done to get it to this point.
Crankshaft and bearings
Oil pump
Oil pan
Map sensor
Battery
All spark plugs
Purge valve solonoid
PCV valve
Any problem vacuum hoses
Fuel pressure regulator
Catalytic converter
O2 sensor
Full fluids change
Water pump visually inspected
Fuel filter cleaned out with no improvement noticed.
Distributor contacts checked and cleaned.
Perhaps another couple odds and ends im not thinking of.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
