Krusty
May 02, 2022Nomad II
I would investigate the catalytic converter further. It sounds similar to an issue I had with my truck. It ran fine with good power most of the time, and intermittently the power would drop right down. It turns out that one of the catalyst "pucks" in the converter had broken in half, and the halves would rattle around in there until one of them became lodged sideways in the outlet of the converter, causing a severe restriction. It would break itself free after a bit, and power would be restored. Not sure you would be able to locate this blockage with a pressure test as it is intermittent. I cut my converter in half and knocked the guts out and welded it back up. Been fine since.
38,782 PostsLatest Activity: Sep 10, 2026
