enblethen
Jan 11, 2015Nomad
Should ask also what the circumstances of the failure.
Was there an engine check light? Did you check for codes? You can do this with a small jumper between the correct pins in the OBD I connector. You install a jumper between pins A& B then turn on ignition and watch for a series of flashes with short breaks between them.
38,708 PostsLatest Activity: Mar 05, 2025
