PaulJ2
Jan 13, 2015Explorer
pimpinfresh1986 wrote:
the only thing that I did not check is the crank position sensor and the camshaft position sensor
I believe you might find your problem being the cam position sensor located in the distributor. It's job is to fire the fuel injectors at the proper time.
Crank position sensor controls the ignition timing.
38,708 PostsLatest Activity: Mar 05, 2025
