garry1p
Dec 05, 2013Explorer
You really need to find out if you have a fuel, electrical or vacuum problem.
One easy test is spraying WD 40 or starter fluid (short squirts) into the throttle body as soon as it starts to see if will continue to run.
Usually vacuum problems will cause a bad idle and not shut down, fuel or electrical can cause the shut down.
38,782 PostsLatest Activity: Sep 10, 2026
