MountainAir05
Jan 04, 2014Explorer II
Sounds like fuel. If memory serves me power is sent to the fuel pump for a 20 seconds or so, then after engine starts the oil pressure switch ensures you have power to fuel pump after you engine starts. You can check to see if your pump is working after startup. You can hook up a fuel pressure gage and see if pressure drops. Also a timing light will show spark.
38,782 PostsLatest Activity: Sep 10, 2026
