2bzy2c
Jan 07, 2014Explorer II
april10 wrote:
Battery appeared to be dead and charger would not charge it. Then I jumped it with my pickup truck, and engine started and continued to run with jumper cables connected. Checked voltage at 13.90 volts, then disconnected jumper cables and voltage started dropping withing about 2 mins down to 8 volts, and engine died. Battery slowly recovered to 11 1/2 volts. Then I put battery back on charger and it read 13 volts, set at 2A charge. Started engine, voltage dropped to approx 8 volts and engine started to die, switched charger to 8 amps, and engine recovered and continued to run. Any ideas on what to do from here?
If you tried starter fluid and that did not help, then the problem is not fuel related.
Look towards your charging system. Based on your observations, you do not have enough voltage to keep the engine running. Alternator would be my guess. Sad thing is, when the alternator goes bad, it drains the battery and more often than not, the battery is bad too.
Take the alternator off and have it tested ay most any auto parts
store.
Best of luck, and please do check back and let us know the outcome. It benefits all of us.
38,782 PostsLatest Activity: Sep 10, 2026
