wildmanbaker
Jan 07, 2014Explorer
Larry probably has it right. There is a minimum voltage at which the ignition will quit working. Battery could be bad, but the alternator should provide voltage to keep it running. Most TBIs will give a small spray of fuel, when the key is first turned on, to help starting. We need to wait for the OP to get back with what they have found out, before we do any more guessing.
38,782 PostsLatest Activity: Sep 10, 2026
