Hi. I have the same rig with different set of stickers on it. The Itasca Suncruiser and the Winnie Adventurer are the same vehicle made by Winnebago. It get 10-11 mpg depending if I am towing or not. The Cummins 5.9L engine and the Allison 542 transmission are bullet-proof reliable, but it is not fast. I'll let others comment about the general items, but one item of concern specific to this coach is the 100 gallon water tank. They tend to fall out onto the road. It happened to me and one other owner in Texas. I managed to contact yet another owner whose tank was ready to drop. Check the 8 support brackets for cracks. I managed to use two 10000lb loading straps to secure the tank because I didn't want to weld so close to nearby propane tank. That happened 8 years ago and it's been good since. Similarly, there is recall on the fuel tank that was probably fixed long ago. Yes they've been falling out too, but mine is fine. While I'm at it, the spare tire has a similar recall for the same crap. So check the two tanks and the spare. The people driving behind you will really appreciate it. We've had our 21 year old Motorhome for 11 years and have received good use out of it. I hope that helps.
