Doc_Eagle
May 12, 2013Explorer
Ok mine is a bit different, on ours the switch is located above a two switch panel, but it is for your electric step. Pretty sure it is a simple SPST switch so it is a matter of elimination. Do your steps work, got ours working just the one bolt has broken and will have to be replaced. You have a multimeter? You can identify the hot wires and go from there. PO broke her ankle on the step so she had been using a two step stool. We are using the stool for a while. Like the graphics in the door, we had to replace our door glass, wife was changing molding around it and it fell out in the parking lot of Campers World, they had the new moldings but not the glass. Went to Lowes and bought a piece of 1/4" plexiglass to replace it. I will have to take some pictures to post on the site, it has been fun and challenging to do some of the projects. I will take the switch out in a little bit to see how it is wired. Maybe I can get the colors for you if it has more than two wires going to it. Hope that helps.
38,766 PostsLatest Activity: Jan 10, 2026
