Doc_Eagle
May 21, 2013Explorer
Well ok the fix worked to level them out. Used a couple of big hex nuts as spacers to drop the back end. Still have to put the wiring back but raining here in good ole SC. Also have to track down a little leak over the door which is draining down onto the bottom step. The PO put a little channel over the door which was a good idea but it is pulled off a little from the camper and believe the water is draining down there. Resealing when weather permits.
38,766 PostsLatest Activity: Jan 10, 2026
